주요 콘텐츠로 건너뛰기
Jensen CD Player Electric Motor Wire Replacement
필요한 것
  1. Jensen CD Player Electric Motor Wire Replacement, Electric Motor Wire: 1 단계, 이미지 1/1
    • Place the CD player face up on a clean surface.
  2. Jensen CD Player Electric Motor Wire Replacement: 2 단계, 이미지 1/1
    • Upturn the CD player and take out the batteries.
    • To take out the batteries, pull back and lift the battery cover.
    • Ensure that the batteries are properly removed, at this step.
  3. Jensen CD Player Electric Motor Wire Replacement: 3 단계, 이미지 1/2 Jensen CD Player Electric Motor Wire Replacement: 3 단계, 이미지 2/2
    • Flip the CD player back and open the lid. You will see two 10 mm Phillips screws on the left and right side under the lid.
    • To open the lid, push the button on the far right with an ejection symbol. Once the button is pushed, carefully lift the lid.
  4. Jensen CD Player Electric Motor Wire Replacement: 4 단계, 이미지 1/2 Jensen CD Player Electric Motor Wire Replacement: 4 단계, 이미지 2/2
    • Unscrew each 10 mm Phillips screw with the screwdriver, and place them outside safely.
    • Note the order in which you took the screws out.
  5. Jensen CD Player Electric Motor Wire Replacement: 5 단계, 이미지 1/2 Jensen CD Player Electric Motor Wire Replacement: 5 단계, 이미지 2/2
    • Turn the CD player upside down and open the battery compartment. You will see one more 10 mm Phillips screw inside. Unscrew it.
    • Use the Phillips screwdriver to remove the screw. Place the screw outside safely.
  6. Jensen CD Player Electric Motor Wire Replacement: 6 단계, 이미지 1/3 Jensen CD Player Electric Motor Wire Replacement: 6 단계, 이미지 2/3 Jensen CD Player Electric Motor Wire Replacement: 6 단계, 이미지 3/3
    • Now, open the CD player, and check the components inside.
    • Be careful as this step requires some force.
  7. Jensen CD Player Electric Motor Wire Replacement: 7 단계, 이미지 1/3 Jensen CD Player Electric Motor Wire Replacement: 7 단계, 이미지 2/3 Jensen CD Player Electric Motor Wire Replacement: 7 단계, 이미지 3/3
    • Locate the motor on the bottom portion of the CD player. Lift the motor up and turn it over.
    • Operate the motor carefully, since it is still connected to some wires.
  8. Jensen CD Player Electric Motor Wire Replacement: 8 단계, 이미지 1/1
    • Locate these two small wires.
    • Check whether both the wires are connected to the electric motor. If not, that is a probable reason why the CDs are not spinning once the device is turned on.
  9. Jensen CD Player Electric Motor Wire Replacement: 9 단계, 이미지 1/2 Jensen CD Player Electric Motor Wire Replacement: 9 단계, 이미지 2/2
    • Resolder the disconnected wires. This is a lengthy procedure.
    • Be cautious, as the soldering iron is hot and may cause skin burns.
    • Make sure to wash your hands after dealing with the solder.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Garrik Kaufman
회원 가입일: 05/31/16
148 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 16
전체 시간: 744
