주요 콘텐츠로 건너뛰기
Jensen JTA-230 Cartridge/Needle Replacement
  1. Jensen JTA-230 Cartridge/Needle Replacement, Cartridge/Needle: 1 단계, 이미지 1/1
    • Open the dust cover
  2. Jensen JTA-230 Cartridge/Needle Replacement: 2 단계, 이미지 1/1
    • Next, lift up the clip that holds the tone arm in place and lift the tone arm out.
  3. Jensen JTA-230 Cartridge/Needle Replacement: 3 단계, 이미지 1/1
    • The cartridge and needle is the red piece at the end of the tone arm. To remove it, simply grab the end on each side and pull back slowly. The piece should slide right off the tone arm
  4. Jensen JTA-230 Cartridge/Needle Replacement: 4 단계, 이미지 1/1
    • Once you have the replacement piece it goes on slight different. Instead of it sliding back on, it clips back on. Once the new piece is secured back on it is good to go.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Louis Varrichione
회원 가입일: 03/11/16
309 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 5,170
