주요 콘텐츠로 건너뛰기
Jensen JTA-230 Motor Replacement
필요한 것
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: 1 단계, 이미지 1/1
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: 2 단계, 이미지 1/1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: 3 단계, 이미지 1/1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: 4 단계, 이미지 1/1
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: 5 단계, 이미지 1/1
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: 6 단계, 이미지 1/2 Jensen JTA-230 Motor Replacement, Motor: 6 단계, 이미지 2/2
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: 7 단계, 이미지 1/2 Jensen JTA-230 Motor Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: 8 단계, 이미지 1/1
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
결론
Robert Wilcox
회원 가입일: 03/04/16
227 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 1,993
