주요 콘텐츠로 건너뛰기
Jensen JTA-230 Speaker Replacement
필요한 것
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: 2 단계, 이미지 1/2 Jensen JTA-230 Speaker Replacement: 2 단계, 이미지 2/2
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: 3 단계, 이미지 1/1
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: 4 단계, 이미지 1/1
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
결론
John Roche
회원 가입일: 03/02/16
175 평판
안내서 1개 작성함
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G8
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
What type of speakers do I need to buy?
Isaac Bott - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 581
