주요 콘텐츠로 건너뛰기
Jensen JTA-230 Turntable Platter Replacement
필요한 것
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: 1 단계, 이미지 1/1
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: 2 단계, 이미지 1/1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: 3 단계, 이미지 1/1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: 4 단계, 이미지 1/1
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: 5 단계, 이미지 1/1
    • Replace Cover
결론
Robert Wilcox
회원 가입일: 03/04/16
227 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G8
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 17
전체 시간: 1,644
