주요 콘텐츠로 건너뛰기
Jensen JTA-230 Volume Knob Replacement
  1. Jensen JTA-230 Volume Knob Replacement, Volume Knob: 1 단계, 이미지 1/1
    • Carefully place on a table where it will hold a lot of pressure
  2. Jensen JTA-230 Volume Knob Replacement: 2 단계, 이미지 1/1
    • Next, using your thumb and finger, get a good grasp on the volume knob, and carefully but forcefully pull on it and it will pop off.
  3. Jensen JTA-230 Volume Knob Replacement: 3 단계, 이미지 1/1
    • Next, take your new volume knob and simply pop it back into place the same way you took the old one off, and you are good to go.
결론
Louis Varrichione
회원 가입일: 03/11/16
309 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G8
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 477
