주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
John Deere 870 Oil Change
필요한 것
  1. John Deere 870 Oil Change, John Deere 870 Oil Change: 1 단계, 이미지 3개 중 1개 John Deere 870 Oil Change, John Deere 870 Oil Change: 1 단계, 이미지 3개 중 2개 John Deere 870 Oil Change, John Deere 870 Oil Change: 1 단계, 이미지 3개 중 3개
    • Let the engine run for a few minutes to warm up the oil before beginning.
    • Pull the hood release latch at the front right of the tractor and lift the hood up.
    댓글 쓰기
  2. John Deere 870 Oil Change: 2 단계, 이미지 2개 중 1개 John Deere 870 Oil Change: 2 단계, 이미지 2개 중 2개
    • Lift the hood prop bar from its seat and place it in the hooks on the underside of the hood.
    댓글 쓰기
  3. John Deere 870 Oil Change: 3 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 3 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 3 단계, 이미지 3개 중 3개
    • The right side engine panel is held in place by two rotating tabs (highlighted in red).
    • Pull each tab straight away from the panel and twist them 90° so that they fit through the slots in the panel.
    • Pull the top of the engine panel straight out until it is free from the tabs.
    • Lift the engine panel up to remove it and set it aside.
    댓글 쓰기
  4. John Deere 870 Oil Change, Draining the old oil: 4 단계, 이미지 3개 중 1개 John Deere 870 Oil Change, Draining the old oil: 4 단계, 이미지 3개 중 2개 John Deere 870 Oil Change, Draining the old oil: 4 단계, 이미지 3개 중 3개
    • The drain plug is a 17 mm hex bolt located on the underside of the tractor.
    • Place an oil drain pan underneath the drain plug to catch the oil when it begins to drain.
    • Use a 17 mm box end wrench to loosen the drain plug 3/4 of a turn.
    댓글 쓰기
  5. John Deere 870 Oil Change: 5 단계, 이미지 2개 중 1개 John Deere 870 Oil Change: 5 단계, 이미지 2개 중 2개
    • Loosen the drain plug by hand until it comes out and oil begins to drain from the oil pan.
    • You may consider using a bucket first to catch the oil, as it may not drain into the oil drain pan quickly, potentially leading to a spill.
    • Watch the draining oil for shiny specks. Small flakes of metal could indicate a problem with your tractor's engine internals.
    댓글 쓰기
  6. John Deere 870 Oil Change: 6 단계, 이미지 2개 중 1개 John Deere 870 Oil Change: 6 단계, 이미지 2개 중 2개
    • While the oil is draining, wipe off the drain plug with a clean rag or towel.
    • Remove the old drain plug gasket and replace it, making sure that the new gasket fits over the threads of the drain plug.
    댓글 쓰기
  7. John Deere 870 Oil Change: 7 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 7 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 7 단계, 이미지 3개 중 3개
    • Wipe down the area around the drain plug with a clean rag or towel.
    • Reinstall the drain plug and tighten it as much as you can by hand.
    • Use a 17 mm box end wrench to tighten the drain plug until it is snug.
    • Do not over-tighten the drain plug. Doing so may strip the threads or crack the oil pan. You can always come back later and tighten the drain plug more if needed.
    댓글 쓰기
  8. John Deere 870 Oil Change, Removing the oil filter: 8 단계, 이미지 3개 중 1개 John Deere 870 Oil Change, Removing the oil filter: 8 단계, 이미지 3개 중 2개 John Deere 870 Oil Change, Removing the oil filter: 8 단계, 이미지 3개 중 3개
    • Move the oil drain pan so that it is directly under the oil filter.
    • Remove the oil filter by turning it counterclockwise until it comes free.
    • When you get the filter removed, check to make sure the gasket is not stuck to the engine. If it is on the engine, remove it.
    • If the filter is on too tightly to remove by hand, use an oil filter wrench to loosen it first, then continue to remove it by hand.
    • Place the oil filter with the open end facing down onto the oil drain pan to allow the old oil to drain out.
    댓글 쓰기
  9. John Deere 870 Oil Change: 9 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 9 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 9 단계, 이미지 3개 중 3개
    • Dip a clean, gloved finger into a fresh bottle of oil and spread a thin layer of oil on the new oil filter's gasket.
    • This layer of oil will help provide a good seal and make removing the filter at the next oil change easier.
    • Wipe off the oil filter threads and contact area on the engine with a clean rag or towel.
    • Place the new oil filter over the threads and turn it clockwise until it is snug.
    댓글 쓰기
  10. John Deere 870 Oil Change, Adding new oil: 10 단계, 이미지 3개 중 1개 John Deere 870 Oil Change, Adding new oil: 10 단계, 이미지 3개 중 2개 John Deere 870 Oil Change, Adding new oil: 10 단계, 이미지 3개 중 3개
    • The oil filler cap is located on top of the engine at the front of the valve cover (highlighted in red).
    • Twist the oil filler cap counterclockwise and remove it from the valve cover.
    댓글 쓰기
  11. John Deere 870 Oil Change: 11 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 11 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 11 단계, 이미지 3개 중 3개
    • Place a funnel in the oil filler hole.
    • Hold the funnel with one hand to steady it and pour 5.1 quarts of 15W-40 oil into the funnel.
    • Reinstall the oil filler cap and turn it clockwise until it is snug.
    댓글 쓰기
  12. John Deere 870 Oil Change: 12 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 12 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 12 단계, 이미지 3개 중 3개
    • The engine oil dipstick is located on the right side of the engine and has a yellow handle.
    • Remove the dipstick, wipe it off with a clean rag or towel, reinsert it, and remove it again.
    • Read the initial oil level. It should be somewhere in the crosshatched region. It is acceptable for the level to be slightly high, since it hasn't filled the oil filter and other nooks and crannies of the engine yet.
    • Reinsert the dipstick and add or remove any oil, if necessary.
    댓글 쓰기
  13. John Deere 870 Oil Change: 13 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 13 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 13 단계, 이미지 3개 중 3개
    • Place the engine panel back in its original location, making sure the two retaining tabs go through their respective slots in the panel.
    • Secure the engine panel by pulling the retaining tabs straight out, turning them 90°, and laying them down flat.
    댓글 쓰기
  14. John Deere 870 Oil Change: 14 단계, 이미지 3개 중 1개 John Deere 870 Oil Change: 14 단계, 이미지 3개 중 2개 John Deere 870 Oil Change: 14 단계, 이미지 3개 중 3개
    • Hold the hood up with one hand and use the other hand to return the hood prop to its original location
    • Close the hood firmly and make sure that the hood latch engages.
    댓글 쓰기
  15. John Deere 870 Oil Change: 15 단계, 이미지 1개 중 1개
    • Allow 12-24 hours for all of the oil to drain out of the old oil filter.
    • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
    댓글 쓰기
결론
If you're lucky, maybe she'll think your tractor is sexy.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
David Hodson
회원 가입일: 04/13/10
156,388 평판
안내서 127개를 작성함
5가이드 댓글
Thanks so much for this guide!! Easy way to find out what oil to use! Kudos
Mike - 답글 공유
David Hodson. I felt I owe acknowledge your generosity. I now own this professional tool that is greatly valuable for a commom latin american guy. G. bless your generations forever. Thank you so much.
Manu Costa - 답글 공유
Clear, concise accurate and exacting pictures with the perfect amount of directions. Fantastic job and best tutorial available for the John Deere 870
Fred Catts-Tucker - 답글 공유
The octane no. is a rating for the antiknocking property of petrol.In the test engine, 100 octane petrol has the same antiknocking as isoheptane and 0 octane same as n-octane.
Osama Siddiq - 답글 공유
I kept my voice low, "I think your !&^&^ likes that." She didn't respond but she did press into me once as I traced a circle around her $^$* through her smooth panties. "Let your !&^&^ get wet," I told her but I had a good idea it already was, the crotch of her panties felt slick and it wasn't just the fabric. I told her to lay still as I began rolling the top of her panties down, I pulled at them from either side until they were down to her mid thigh. Again I slid my fingers between her legs and I instantly felt that she was soaking wet, there was no resistance as I moved my finger to dip into her !&^&^. I began rapidly moving my finger so that it would just barely penetrate her and then popping it back out, I could hear the wet smacking sound the motion made, her body was beginning to tense as she focused on the sensation big booty !!%@ I pressed on her hip with my other hand and told her to lay on her tummy, without a word she layed face down in a fluid motion but still without saying anything to me
Dona Zwar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 117
전체 시간: 27,484
