주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Jolla 수리는 저희 서비스 설명서를 사용하십시오.
  1. Jolla Teardown, Jolla: 1 단계, 이미지 1/1
    • Turn it off!
  2. Jolla Teardown, Back cover: 2 단계, 이미지 1/3 Jolla Teardown, Back cover: 2 단계, 이미지 2/3 Jolla Teardown, Back cover: 2 단계, 이미지 3/3
    • Remove the back cover by pulling up from the bottom right hand corner. Remove the bottom first and then the sides.
  3. Jolla Teardown, Battery, sim card and MicroSD Card: 3 단계, 이미지 1/2 Jolla Teardown, Battery, sim card and MicroSD Card: 3 단계, 이미지 2/2
    • Remove battery from the small space near the bottom of the phone.
    • Remove the sim card by pulling the plastic flap to the right and pulling/pushing the sim card downwards.
    • Remove the MicroSD card by pushing up from the bottom until it clicks. It will then ping down.
  4. Jolla Teardown: 4 단계, 이미지 1/1
    • Remove 11 T5 screws.
  5. Jolla Teardown, Remove the back frame: 5 단계, 이미지 1/3 Jolla Teardown, Remove the back frame: 5 단계, 이미지 2/3 Jolla Teardown, Remove the back frame: 5 단계, 이미지 3/3
    • Pull up from the bottom corners, remove the bottom first and then the sides.
    • The volume and power buttons may fall out at this point. Don't lose them.
  6. Jolla Teardown, Inner frame.: 6 단계, 이미지 1/3 Jolla Teardown, Inner frame.: 6 단계, 이미지 2/3 Jolla Teardown, Inner frame.: 6 단계, 이미지 3/3
    • Remove this T5 screw from the bottom left hand side. This is the only screw holding in the inner frame.
    • The frame should lift out and up from the phone.
    • If your volume button and power button haven't fallen out yet, they will now.
  7. Jolla Teardown, Connectors: 7 단계, 이미지 1/2 Jolla Teardown, Connectors: 7 단계, 이미지 2/2
    • Two connectors on the top right hand side.
    • 3 connectors on the right hand side about half way down the phone.
  8. Jolla Teardown, Antenna: 8 단계, 이미지 1/3 Jolla Teardown, Antenna: 8 단계, 이미지 2/3 Jolla Teardown, Antenna: 8 단계, 이미지 3/3
    • Remove one end from here.
    • The other end can be removed here.
  9. Jolla Teardown, Circuit board: 9 단계, 이미지 1/3 Jolla Teardown, Circuit board: 9 단계, 이미지 2/3 Jolla Teardown, Circuit board: 9 단계, 이미지 3/3
    • The circuit board is held in place by one T5 screw.
    • Use a spudger to gently pry the circuit board upwards. Do this on both sides.
    • It should lift out quite easily.
  10. Jolla Teardown, Small circuit board: 10 단계, 이미지 1/3 Jolla Teardown, Small circuit board: 10 단계, 이미지 2/3 Jolla Teardown, Small circuit board: 10 단계, 이미지 3/3
    • The second circuit board can be removed after removing the connector attached to it and gently prying it off. It's fixed in place by a small amount of glue.
  11. Jolla Teardown, Cameras: 11 단계, 이미지 1/3 Jolla Teardown, Cameras: 11 단계, 이미지 2/3 Jolla Teardown, Cameras: 11 단계, 이미지 3/3
    • Main camera.
    • Secondary camera.
  12. Jolla Teardown, Done!: 12 단계, 이미지 1/1
    • I won't be removing the screen in this teardown as replacement screens for the Jolla phone are not very easily available at the moment.
Shannon McWilliam
회원 가입일: 12/01/15
25 평판
안내서 1개 작성함
댓글 한 개
So far so easy. I might be able to get hold of a new Screen/Digitizer for my good old Jolla (finally removing this annoying spider app ;-) ). Would be nice if you could say a few words about going on from where you stoped. It seems to me that the rest is more or less one piece being molded together or something. What else is there to remove, besides small parts like earpiece, mic, audioconnector, flat cables, etc.
Is the digitizer-glass just glued in so I could pry off the pieces of mine and replace it with a new one?
Would be very nice to hear from you and thanks a lot for the tear down, was very helpfull so far.
FYI: Spare parts available at maxbhi.com, though I don't trust that shop very much ;-)
Matthias Twittmann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 58
전체 시간: 4,726
