소개
Use this guide to replace the buckle lock in a Nintendo Switch Joy-Con with a metal one, or a new plastic one.
There are a few minor differences between the left and right Joy-Cons, but none that will affect the procedure. These steps apply to both Joy-Cons.
필요한 것
Use a Tri-point Y00 driver to remove the four 6.3 mm-long screws from the back panel of the Joy-Con.
Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
With the charging rail facing away from you, open the the Joy-Con like a book.
Use a Phillips #00 driver to remove the 2.5 mm screw securing the charging rail.
Use a Phillips #00 driver to remove the screw securing the buckle lock retaining bracket.
Slide one side of a pair of pointed tweezers under the flat part in the middle of the buckle lock bracket.
Grasp the bracket with the tweezers and pull the bracket straight away from the charging rail to remove it.
Lift the buckle lock slightly out of its slot in the charging rail, just until the spring is exposed enough that you can grab it with tweezers.
Grab the buckle lock such that the tweezers are around both sides of the lock and holding the spring inside the lock.
Pull the buckle lock out of its slot in the charging rail.
다른 114명이 해당 안내서를 완성하였습니다.
댓글 34개
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
It seems rather strange.. Its pretty easy to reattach. All I have is a $@$*!& ph00 + y00 that stripped the screws so I broke the cover. Technically not my fault. I have done multiple reshells.
I tryed to do this but the 2nd at the bottom would not come out now my buckle is chiped
You mean the screws? Break off the shell! A perfect opportunity to put some clear ones :))
I bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/gp/product/B07BDH...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping $9.00 will set you up right.
I did have a bit of trouble replacing the metal cover that holds the buckle in place, but that was my own stupidity as I was trying to do this repair with insufficient light. Once I shed some light on the subject and I could see what I was doing, everything went back together smooth as silk. I replaced the buckles on both of my Joy Cons, and they’re both rock solid now.
