주요 콘텐츠로 건너뛰기
Joy-Con ZL Switch Replacement
필요한 것
  1. Joy-Con ZL Switch Replacement, Unscrew the back cover: 1 단계, 이미지 1개 중 1개
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
  2. 이 단계에 사용된 도구:
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  3. Joy-Con ZL Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Resume gameplay!
  4. Joy-Con ZL Switch Replacement, The problem part: 6 단계, 이미지 2개 중 1개 Joy-Con ZL Switch Replacement, The problem part: 6 단계, 이미지 2개 중 2개
    • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
    • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
  5. Joy-Con ZL Switch Replacement, Splitting it apart: 7 단계, 이미지 3개 중 1개 Joy-Con ZL Switch Replacement, Splitting it apart: 7 단계, 이미지 3개 중 2개 Joy-Con ZL Switch Replacement, Splitting it apart: 7 단계, 이미지 3개 중 3개
    • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
    • Remove the holding screw.
  6. Joy-Con ZL Switch Replacement, Pop out the battery: 8 단계, 이미지 2개 중 1개 Joy-Con ZL Switch Replacement, Pop out the battery: 8 단계, 이미지 2개 중 2개
    • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
    • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
  7. Joy-Con ZL Switch Replacement, Remove the battery tray: 9 단계, 이미지 2개 중 1개 Joy-Con ZL Switch Replacement, Remove the battery tray: 9 단계, 이미지 2개 중 2개
    • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
    • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
  8. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently pull on the ribbon cable to remove the plug from the socket.
    • Insert plug on new ribbon cable & switch.
    • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
  9. Joy-Con ZL Switch Replacement, Putting it back together: 11 단계, 이미지 1개 중 1개
    • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
    • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
    • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
  10. Joy-Con ZL Switch Replacement, Yippee it works!: 12 단계, 이미지 3개 중 1개 Joy-Con ZL Switch Replacement, Yippee it works!: 12 단계, 이미지 3개 중 2개 Joy-Con ZL Switch Replacement, Yippee it works!: 12 단계, 이미지 3개 중 3개
    • Put the two springs back on their retaining pins and push the button back into place.
    • It should click into place and when you push on the button you should hear the switch click.
    • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robin Razzell
회원 가입일: 09/04/13
340 평판
안내서 2개를 작성함
1가이드 댓글
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 83
지난 30일: 326
전체 시간: 11,823
