주요 콘텐츠로 건너뛰기
소개
Before you begin, you will need a flathead screwdriver, thread, and a 175X7 size 18 sewing needle.
부품
  1. Pass the thread through the needle eye.
    • Pass the thread through the needle eye.
  2. Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
    • Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
  3. Continue the threading, weaving through the pull-off lever.
    • Continue the threading, weaving through the pull-off lever.
  4. Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right. Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
    • Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
  5. Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
    • Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
  6. Weave threading through the working arm and have it ready to insert through the eye of the needle.
    • Weave threading through the working arm and have it ready to insert through the eye of the needle.
  7. Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
    • Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
  8. Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
    • Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
  9. Insert the thread through the eye of the needle, and you are ready for sewing.
    • Insert the thread through the eye of the needle, and you are ready for sewing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connor Cherry
회원 가입일: 2019년 02월 04일
196 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 59
