이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
Weave threading through the working arm and have it ready to insert through the eye of the needle.
Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
Insert the thread through the eye of the needle, and you are ready for sewing.
다른 한 분이 해당 안내서를 완성하였습니다.
