주요 콘텐츠로 건너뛰기
Jumper Angelsounds JPD-100S Battery Cable Replacement
필요한 것
  1. Jumper Angelsounds JPD-100S Battery Cable Replacement, Motherboard: 1 단계, 이미지 1/1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Battery Cable Replacement: 2 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 2 단계, 이미지 2/2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Battery Cable Replacement: 3 단계, 이미지 1/1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Battery Cable Replacement: 4 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 4 단계, 이미지 2/2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Battery Cable Replacement: 5 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 5 단계, 이미지 2/2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Battery Cable Replacement: 6 단계, 이미지 1/1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Battery Cable Replacement: 7 단계, 이미지 1/1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: 8 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: 8 단계, 이미지 2/2
    • Preheat soldering iron.
    • Locate the battery cable leads on the motherboard.
  9. Jumper Angelsounds JPD-100S Battery Cable Replacement: 9 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 9 단계, 이미지 2/2
    • Use a soldering iron and solder vacuum to unsolder the battery cable leads.
  10. Jumper Angelsounds JPD-100S Battery Cable Replacement: 10 단계, 이미지 1/1
    • Remove the battery cables by pulling them out of the motherboard.
결론
Safiyah Junaid
회원 가입일: 08/31/15
125 평판
안내서 1개 작성함
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G1
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 15
전체 시간: 390
