주요 콘텐츠로 건너뛰기
Jumper Angelsounds JPD-100S Headphone Jacks Replacement
필요한 것
  1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Motherboard: 1 단계, 이미지 1/1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 2 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 2 단계, 이미지 2/2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 3 단계, 이미지 1/1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 4 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 4 단계, 이미지 2/2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 5 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 5 단계, 이미지 2/2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 6 단계, 이미지 1/1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 7 단계, 이미지 1/1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Headphone Jacks: 8 단계, 이미지 1/1
    • Take the battery connector out of the battery compartment.
  9. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 9 단계, 이미지 1/1
    • Preheat the soldering iron .
    • Locate the wires that connect to the transducer.
    • Use a soldering iron and solder vacuum to unsolder the wires connected to the transducer.
  10. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 10 단계, 이미지 1/2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 10 단계, 이미지 2/2
    • Place the motherboard in a position that allows easy access to the jacks.
  11. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 11 단계, 이미지 1/3 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 11 단계, 이미지 2/3 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 11 단계, 이미지 3/3
    • Desolder the three solder joints securing each of the headphone jacks.
    • Try not to melt the motherboard when removing solder that secures the jacks.
  12. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 12 단계, 이미지 1/1
    • Remove the jacks by pulling them out of the motherboard.
결론
Yessika Lugo
회원 가입일: 08/31/15
113 평판
안내서 1개 작성함
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G1
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 384
