주요 콘텐츠로 건너뛰기
Jumper Angelsounds JPD-100S Motherboard Replacement
필요한 것
  1. Jumper Angelsounds JPD-100S Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Jumper Angelsounds JPD-100S Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Jumper Angelsounds JPD-100S Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Jumper Angelsounds JPD-100S Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
결승점
작성자
2다른 기여자 명과 함께
Deron Rogers
회원 가입일: 08/31/15
271 평판
안내서 2개를 작성함
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G1
6 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 261
