소개
The flowmeter measures how much water is supplied by the water tank. If this measurement is disturbed, the coffee machine will no longer function properly or not at all. A typical error is the message "Fill system", which does not go away because the electronics do not receive a message about the water flow. Most of the time the flowmeter is calcified and just needs to be cleaned.
필요한 것
Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
The motor for the drainage valve is located in the lower side of the unit near the center. It is fastened with three screws and connected with several flat plugs. In the picture, the ceramic valve has already been pushed off.
The flowmeter is inserted in the front area of the device next to the brewing group. The inlet on the front is easy to see and can be carefully pushed off.
Blow into the lower inlet nozzle of the flow meter. You should hear the turbine whirring nicely.
The flowmeter can be opened easily. Twist the top clockwise a little and take it off. Pay attention to the gasket when assembling.
The inlet channel is very thin, this is where most of the dirt settles. Take a needle and poke the opening.
Clean the flowmeter well and put it back together
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
In meinem Fall funktionierte das neue Flowmeter nach dem Tausch gar nicht, habe dann das alte gereinigt und wieder montiert. Das hat auch geklappt. Im Grunde kann an dem Bauteil nichts kaputt gehen, also eine Reinigung sollte in der Regel ausreichen. Wenn man dann hineinbläst muss erkennbar sein das sich das Flügelrat dreht. Dann sollte es wieder funktional sein.
