주요 콘텐츠로 건너뛰기
Jura Capresso IMPRESSA J5 Magnetic Drainage Valve
필요한 것
  1. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve, Jura Capresso IMPRESSA J5  opening procedure: 1 단계, 이미지 1/1
    • Unplug the power cord!
    • Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
  2. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 2 단계, 이미지 1/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 2 단계, 이미지 2/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 2 단계, 이미지 3/3
    • Flip open the lid of the bean compartment.
    • Unscrew the two slotted screws inside the bean compartment. The screws have a rubber washer and will not come out completely.
    • Remove the bean compartment.
  3. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 3 단계, 이미지 1/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 3 단계, 이미지 2/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    구매
    • The top cover is fastened with oval head screws. Unscrew them.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!
  4. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 4 단계, 이미지 1/1
    • Also remove the two oval head screws underneath the ground coffee compartment lid.
  5. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 5 단계, 이미지 1/1
    • Now you can pry up the top cover all around.
    • Remove the top cover. This often requires a little force.
    • Use plastic tools to avoid scratching your device.
  6. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 6 단계, 이미지 1/2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 6 단계, 이미지 2/2
    • Turn the device with the back facing you.
    • Turn the Jura label a few degrees counterclockwise. If it's hard to do, use a small suction cup.
    • Remove the Jura label.
  7. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 7 단계, 이미지 1/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 7 단계, 이미지 2/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 7 단계, 이미지 3/3
    • Underneath the label you will find two Torx T15 screws. Remove them.
    • Carefully pull the top of the chrome cover slightly outwards, then push it down and put it aside.
  8. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 8 단계, 이미지 1/1
    • Remove the Torx T15 screw on the side panel with the water tank.
  9. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 9 단계, 이미지 1/2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 9 단계, 이미지 2/2
    • Pull the right side panel slightly towards the back.
    • Remove the side panel.
  10. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 10 단계, 이미지 1/1
    • Pull the left side panel slightly towards the back and remove it.
  11. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve, Jura J5 Magnetic Drainage Valve: 11 단계, 이미지 1/1
    • The motor for the drainage valve is located in the lower side of the unit near the center. It is fastened with three screws and connected with several flat plugs. In the picture, the ceramic valve has already been pushed off.
    • Note: models from J6 onwards have a motor installed and not a magnet.
  12. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 12 단계, 이미지 1/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 12 단계, 이미지 2/3 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 12 단계, 이미지 3/3
    • Unscrew the three Torx T15 screws on the motor for the drain valve. Pay attention to the washers underneath.
    • Carefully pull out the motor.
    • If you want to replace it, you still have to disconnect the flat connectors. Note where the connectors are connected.
결론
Work through the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
209,996 평판
안내서 255개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
26 회원들
안내서 1,185개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 924
