주요 콘텐츠로 건너뛰기
Jura Heater Replacement
필요한 것
  1. Jura Heater Replacement, Jura Impressa Type C E F opening procedure: 1 단계, 이미지 1/1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Jura Heater Replacement: 2 단계, 이미지 1/3 Jura Heater Replacement: 2 단계, 이미지 2/3 Jura Heater Replacement: 2 단계, 이미지 3/3
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Jura Heater Replacement, Pull the plug!!: 3 단계, 이미지 1/1
    • Is the plug really pulled?
  4. Jura Heater Replacement, The thermoblock: 4 단계, 이미지 1/3 Jura Heater Replacement, The thermoblock: 4 단계, 이미지 2/3 Jura Heater Replacement, The thermoblock: 4 단계, 이미지 3/3
    • The block is marked red here.
    • Older models have a completely differently shaped thermoblock. (Pictures 3). The guide for this you can find here.
    • There are three connections for water or steam.
    • Three cable feeders.
    • A thermocouple.
  5. Jura Heater Replacement, Release connections: 5 단계, 이미지 1/3 Jura Heater Replacement, Release connections: 5 단계, 이미지 2/3 Jura Heater Replacement, Release connections: 5 단계, 이미지 3/3
    • First, pull the clips on the tubing connectors, then pull out the tubing.
    • Then remove the power cables: A gray cable leading to the thermal fuse, a blue one directly from the heater (can also be pulled later) and the green-yellow protective cable is unscrewed.
    • Two small blue cables lead to the temperature sensor, it is unscrewed.
    • The hexagon screw in the middle can be loosened.
    • Unscrew the tube holder, then the block is free.
  6. Jura Heater Replacement, exchange: 6 단계, 이미지 1/1
    • Here lies the block. If you are lucky you can push out blockages from the openings with a wire. Mostly that does not work. The block can not be opened and must then be replaced.
    • This is the thermal fuse. First remove the cable lug, then unscrew and fix together with the cable on the new block, as well as the yellow-green protective cable.
  7. Jura Heater Replacement, Assembly of the new block 1: 7 단계, 이미지 1/3 Jura Heater Replacement, Assembly of the new block 1: 7 단계, 이미지 2/3 Jura Heater Replacement, Assembly of the new block 1: 7 단계, 이미지 3/3
    • For mounting, the light carrier must be pulled out by loosening the marked screw.
    • It is attached with two hooks, you can lift them with a screwdriver.
    • The steam valve is actuated by a plastic disc with a cross-shaped cut. To loosen, you have to pull the whole front wall carefully outwards, then you can pull out the entire unit.
  8. Jura Heater Replacement, Assembly of the new block 2: 8 단계, 이미지 1/1
    • Now you can see why all this was necessary: on the back of the carrier is a recess. Inside is loosely the lock nut to the big screw with which the block is attached.
    • Thus, first the new block is screwed into the carrier.
    • And now go through all the steps again in reverse order!
결론
Repeat the steps in reverse order to reassemble your device.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
204,177 평판
안내서 246개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
25 회원들
안내서 1,132개 작성하였습니다
댓글 2개
I would love to see a disassembly of the Jura pancake-style Thermoblock to Rebuild the seals. Great work!
Lisa W - 답글
Thank you. :-) . Pancake style, thats funny. Next time I have one under my screwdrivers I'll shoot some pictures.
VauWeh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 125
전체 시간: 6,168
