소개
The steam valve is located behind the rotary knob at the top right. It is used to control the extraction of steam and hot water. The valve can have various malfunctions: it can be sluggish, leaky, or clogged. Often it is possible to repair the malfunction, replace a gasket, or remove traces of lime scale. This is shown here.
Note: There are different models of this valve. Your valve may look a little different, but the procedure is basically the same.
필요한 것
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
Remove the knob for the steam valve by simply pulling it off.
The front cover is secured with a Torx T15 screw. Remove it.
Loosen the clips on the black cover and carefully lift it off.
Pull out all hose connections. There are small O-rings at the ends, they may also be stuck in the valve body. Remove the O-rings and replace them with new ones when reassembling.
Note exactly where which hose is connected, e.g. by taking a photo, or mark the connection points. In the third photo, the connections are marked (this may also look different on some models):
H = Heating
S = Steam generator on
S = Steam generator off
A= Pressure release valve (elbow)
P = Pump
Turn the valve bonnet over. The molded seal becomes visible. Make sure that it is seated correctly; it must be seated in the valve body again later, otherwise the valve will not work.
Carefully lift out the molded seal and the two ceramic washers. Note the exact installation position.
Now you can clean all parts. If the seal is defective, you need to replace it.
Work through the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 11개
How can i find the right hose connections? I have a Jura S75, and i lost my picture about the connections.
See 3rd picture in step 9
VauWeh -
I connencted like that, but at the bottom of the brewing unit there is a pipe and the water flushes from that. Maybe i connencted a wrong pipe?
M Hunor -
OK, here are two documents (in german), which will hopefully help:
(1) https://www.yumpu.com/de/document/read/7...
(2)
VauWeh -
Follow the way of the water! The pipe on the bottom of the brewing unit leads into the drainage valve. Normally this is closed and the fresh hot water coming from the ceramic valve via heater flows into the lower piston and changes to coffee. It only opens - the loud "clack" - for a short moment, when the brewing cycle ends for pressure release. Maybe the drainage valve is permanent open?
VauWeh -
