주요 콘텐츠로 건너뛰기
Jura Impressa S model Water Reservoir Seal Replacement
필요한 것
  1. Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 1 단계, 이미지 1/3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 1 단계, 이미지 2/3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 1 단계, 이미지 3/3
    • Remove the water reservoir.
    • Turn the Jura on its side to have access to the bottom plate
    • The water connector is protected by a plastic cover, which is secured by two plastic rivets.
    • Use some pliers and squeeze the rivets tightly and push them up until they release.
    • Carefully pry up the plastic cover.
    • Insert the new gasket with the flat side facing up.
    • Give some food-proof lubricant to the new seal and replace it.
결론
To reassemble your device, follow these steps in reverse order
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
210,196 평판
안내서 255개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
26 회원들
안내서 1,186개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 705
