주요 콘텐츠로 건너뛰기
Jura Impressa S model backpanel
필요한 것
  1. Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: 1 단계, 이미지 1/2 Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: 1 단계, 이미지 2/2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model backpanel: 2 단계, 이미지 1/2 Jura Impressa S model backpanel: 2 단계, 이미지 2/2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model backpanel: 3 단계, 이미지 1/1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model backpanel, Jura Impressa S model backpanel: 4 단계, 이미지 1/3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: 4 단계, 이미지 2/3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    구매
    • The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
    • Remove the two oval head screws on the lower edge of the backpanel.
    • Lift the panel up.
결론
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
202,869 평판
안내서 246개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
25 회원들
안내서 1,111개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 712
