주요 콘텐츠로 건너뛰기
Jura Impressa S model front cover
필요한 것
  1. Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 1 단계, 이미지 1/2 Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 1 단계, 이미지 2/2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model front cover: 2 단계, 이미지 1/2 Jura Impressa S model front cover: 2 단계, 이미지 2/2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model front cover: 3 단계, 이미지 1/1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model front cover, Jura Impressa S model front cover: 4 단계, 이미지 1/2 Jura Impressa S model front cover, Jura Impressa S model front cover: 4 단계, 이미지 2/2
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  5. Jura Impressa S model front cover: 5 단계, 이미지 1/1
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  6. Jura Impressa S model front cover: 6 단계, 이미지 1/1
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  7. Jura Impressa S model front cover: 7 단계, 이미지 1/1
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
결론
To reassemble your device, follow these instructions in reverse order
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
202,869 평판
안내서 246개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
25 회원들
안내서 1,111개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 692
