주요 콘텐츠로 건너뛰기
Jura heating cartridge replacement
필요한 것
  1. Jura heating cartridge replacement, Jura Impressa Type C E F opening procedure: 1 단계, 이미지 1/1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Jura heating cartridge replacement: 2 단계, 이미지 1/3 Jura heating cartridge replacement: 2 단계, 이미지 2/3 Jura heating cartridge replacement: 2 단계, 이미지 3/3
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Jura heating cartridge replacement, Heating cartridge: 3 단계, 이미지 1/2 Jura heating cartridge replacement, Heating cartridge: 3 단계, 이미지 2/2
    • The heating cartridge is the aluminum cylinder under the right side, around which spirals the heating runs. It is bolted to a plastic slide. The next steps will show how to pull out the slide and remove all connections.
    • If the boiler looks like the second picture, it is the thermoblock. There is another guide here.
  4. Jura heating cartridge replacement: 4 단계, 이미지 1/3 Jura heating cartridge replacement: 4 단계, 이미지 2/3 Jura heating cartridge replacement: 4 단계, 이미지 3/3
    • The pressure hoses are secured against slipping out with metal clips. Pull out the metal clamp on the hose between the pump and the heating cartridge
    • Disconnect the hose from the pump. Pay attention to the little seal, it probably lingers afterwards. It is good to replace them with a new one when assembling.
  5. Jura heating cartridge replacement: 5 단계, 이미지 1/3 Jura heating cartridge replacement: 5 단계, 이미지 2/3 Jura heating cartridge replacement: 5 단계, 이미지 3/3
    • The carriage of the heating cartridge is held with two black plastic frames. Press it up with a screwdriver until the carriage comes free.
    • Put the screwdriver into the gap that has opened behind the carriage and lift the carriage forward about 5 mm.
  6. Jura heating cartridge replacement: 6 단계, 이미지 1/2 Jura heating cartridge replacement: 6 단계, 이미지 2/2
    • In this step, you must disconnect the connection between the steam knob and the steam valve. The button has two pins stuck in a round plate with a cruciform incision. The steam valve also has two pins which engage in this plate from the other side.
    • Pull the front forward about 1 cm until the pins of the knuckle release from the round plate. Then pull out the carriage with the heating cartridge about 2 cm.
  7. Jura heating cartridge replacement: 7 단계, 이미지 1/1
    • The microswitch is held in place by a black plastic fabric. Push the catch to the left and lift the microswitch out. The cables can stay connected.
  8. Jura heating cartridge replacement: 8 단계, 이미지 1/2 Jura heating cartridge replacement: 8 단계, 이미지 2/2
    • Pull out the clamp on the pressure hose that comes out of the outlet valve.
    • Detach the pressure hose. Watch out for the little seal, it's probably stuck in the valve. It is good to replace them with a new one when assembling.
  9. Jura heating cartridge replacement: 9 단계, 이미지 1/1
    • Now pull out the carriage with the heating cartridge completely and put it on the work table.
    • The heating cartridge is still connected with different cables. Make sure that no cable is damaged.
  10. Jura heating cartridge replacement: 10 단계, 이미지 1/1
    • Pull the clamp on the hose to the steam outlet.
    • Carefully pull out the hose. Pay attention to the little seal, it probably lingers afterwards. It is good to replace it with a new one when assembling.
    • In the next steps you will see how you can solve the connections.
  11. Jura heating cartridge replacement: 11 단계, 이미지 1/1
    • The yellow-green grounding cable is attached with a Phillips screw. Turn it out and disconnect the cable.
  12. Jura heating cartridge replacement: 12 단계, 이미지 1/1
    • Remove the cable lug with the blue cable from the heater.
  13. Jura heating cartridge replacement: 13 단계, 이미지 1/2 Jura heating cartridge replacement: 13 단계, 이미지 2/2
    • The temperature sensor is fastened with a holding plate and a Torx 20 screw.
    • Unscrew the screw, lift the plate with the thermocouple and remove it.
  14. Jura heating cartridge replacement: 14 단계, 이미지 1/1
    • There is a thermal fuse on the gray cable between the heater and the pump. It is attached to the heating cartridge with a retaining plate.
    • Loosen the Torx 15 screw on the retaining plate of the thermal fuse.
    • Remove the thermal fuse from the thermoblock.
    • Disconnect the cable lug from the gray cable on the heater.
  15. Jura heating cartridge replacement: 15 단계, 이미지 1/1
    • The heating cartridge is free.
    • Depending on what your replacement part looks like, you'll need to dismantle more components and transfer them to your replacement part. Here are some hints in the next steps.
  16. Jura heating cartridge replacement: 16 단계, 이미지 1/2 Jura heating cartridge replacement: 16 단계, 이미지 2/2
    • Turn out the long Torx 20 screw on the top of the steam valve.
    • Gently pull off the steam valve.
    • Between the steam valve and heating cartridge is a sealing ring and a black plastic spacer. You should replace the seal, you can continue to use the spacer ring.
  17. Jura heating cartridge replacement: 17 단계, 이미지 1/1
    • When the steam valve is removed, you can finally replace the sled. To do this, turn out three Torx 20 screws.
    • That's the screw on the steam valve, which you removed in the last step.
  18. Jura heating cartridge replacement: 18 단계, 이미지 1/1
    • The clamp for the rotary knob on the steam valve is fastened with a Torx 15 screw. Unscrew it, remove the clamp and transfer it to the new part, if necessary.
    • The pressure hose is attached to the lower end of the heating cartridge with a Legris connection. Press the pressure hose firmly with your fingers towards the heating cartridge. Now push the small ring at the end of the Legris connection towards the heating cartridge and pull off the pressure hose at the same time.
결론
Work the steps in the reverse order to assemble your device again.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
172,542 평판
안내서 219개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
11 회원들
안내서 772개 작성하였습니다
댓글 한 개
DO YOU HAVE THE REPAIR MANUAL FOR THE jURA SUBITO 630 B2 TYP 968 ESPRESSO MACHINE AND THE SPECIAL KEY TO OPEN THE MACHINE ian@helian.net.au
Ian Bersten - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 69
전체 시간: 3,082
