주요 콘텐츠로 건너뛰기
K5 Desktop Humidifier Cotton Swab Filter Replacement
필요한 것
  1. K5 Desktop Humidifier Cotton Swab Filter Replacement, Cotton Swab Filter: 1 단계, 이미지 1/1
    • Press and hold the humidifier switch. Check whether the connection to the power supply still works.
    • The purpose is to rule out a power failure that would render the humidifier inoperable.
  2. K5 Desktop Humidifier Cotton Swab Filter Replacement: 2 단계, 이미지 1/1
    • Use the spudger to slowly pry the middle part of the humidifier at the seam.
    • Be slow to open it, otherwise the humidifier outer body could be damaged.
  3. K5 Desktop Humidifier Cotton Swab Filter Replacement: 3 단계, 이미지 1/3 K5 Desktop Humidifier Cotton Swab Filter Replacement: 3 단계, 이미지 2/3 K5 Desktop Humidifier Cotton Swab Filter Replacement: 3 단계, 이미지 3/3
    • Remove the cotton swab and spring from inside the humidifier.
  4. K5 Desktop Humidifier Cotton Swab Filter Replacement: 4 단계, 이미지 1/1
    • Replace the old cotton swab filter with the new cotton swab.
  5. K5 Desktop Humidifier Cotton Swab Filter Replacement: 5 단계, 이미지 1/3 K5 Desktop Humidifier Cotton Swab Filter Replacement: 5 단계, 이미지 2/3 K5 Desktop Humidifier Cotton Swab Filter Replacement: 5 단계, 이미지 3/3
    • Put the new cotton swab into the humidifier.
    • Hand tighten the part where the cotton swab and humidifier meet.
    • The picture shows how it looks when fully installed.
  6. K5 Desktop Humidifier Cotton Swab Filter Replacement: 6 단계, 이미지 1/1
    • Reassemble the humidifier by snapping on the top half.
  7. K5 Desktop Humidifier Cotton Swab Filter Replacement: 7 단계, 이미지 1/1
    • Plug in the power adaptor to your USB port to use.
결론
YikunFang
회원 가입일: 01/13/22
169 평판
안내서 1개 작성함
York University, Team R-10, Melo-Thaiss Winter 2022 York University, Team R-10, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG10
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 38
전체 시간: 1,574
