주요 콘텐츠로 건너뛰기
KATCHY Insect Trap Disassembly and Clean
필요한 것
  1. KATCHY Insect Trap Disassembly and Clean, KATCHY Insect Trap Disassembly and Clean: 1 단계, 이미지 2개 중 1개 KATCHY Insect Trap Disassembly and Clean, KATCHY Insect Trap Disassembly and Clean: 1 단계, 이미지 2개 중 2개
    • Unplug the power plug from the device.
  2. KATCHY Insect Trap Disassembly and Clean: 2 단계, 이미지 1개 중 1개
    • Open the tray lid to remove the used insect trap.
  3. KATCHY Insect Trap Disassembly and Clean: 3 단계, 이미지 2개 중 1개 KATCHY Insect Trap Disassembly and Clean: 3 단계, 이미지 2개 중 2개
    • Flip the device upside down while leaving the tray lid open.
  4. KATCHY Insect Trap Disassembly and Clean: 4 단계, 이미지 1개 중 1개
    • Remove the mesh from the base.
  5. KATCHY Insect Trap Disassembly and Clean: 5 단계, 이미지 1개 중 1개
    • Unlock the vent and UV light bar.
  6. KATCHY Insect Trap Disassembly and Clean: 6 단계, 이미지 2개 중 1개 KATCHY Insect Trap Disassembly and Clean: 6 단계, 이미지 2개 중 2개
    • Optional: Push the circuit cover case away from the clip to unclip and clean.
  7. KATCHY Insect Trap Disassembly and Clean: 7 단계, 이미지 2개 중 1개 KATCHY Insect Trap Disassembly and Clean: 7 단계, 이미지 2개 중 2개
    • Flip the device so that it is no longer upside down.
    • If the top cover is stuck, grab onto the base and push the cover out with your thumb.
  8. KATCHY Insect Trap Disassembly and Clean: 8 단계, 이미지 1개 중 1개
    • Be careful not to damage the wire connecting it to the base. They should be connected still.
  9. KATCHY Insect Trap Disassembly and Clean: 9 단계, 이미지 2개 중 1개 KATCHY Insect Trap Disassembly and Clean: 9 단계, 이미지 2개 중 2개
    • (Extra) Two screws are protecting the circuit board if you want to do something with it.
  10. KATCHY Insect Trap Disassembly and Clean: 10 단계, 이미지 1개 중 1개
    • Double-check that the fan has no dust to ensure the motor will run more efficiently with less dust.
결론
To reassemble your device, follow these instructions in reverse order. Plug the power supply into the device and check if everything works. The UV light should display like normal.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ryan
회원 가입일: 03/20/24
244 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 158
전체 시간: 2,552
