주요 콘텐츠로 건너뛰기
KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
필요한 것
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: 1 단계, 이미지 3개 중 3개
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Proceed to remove the surrounding keycaps.
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 5 단계, 이미지 3개 중 3개
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 7 단계, 이미지 3개 중 3개
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 8 단계, 이미지 3개 중 3개
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 10 단계, 이미지 3개 중 3개
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 11 단계, 이미지 3개 중 3개
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 3개 중 1개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 3개 중 2개 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: 12 단계, 이미지 3개 중 3개
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
결론
To reassemble your device, follow these instructions in reverse order starting at step 7.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kenny Nguyen
회원 가입일: 07/05/20
259 평판
안내서 1개를 작성함
York University, Team S1-G40, Allen Summer 2020 York University, Team S1-G40, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G40
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 18
전체 시간: 1,789
