주요 콘텐츠로 건너뛰기
KDDI Kyocera A5521K Front LCD Screen Replacement
필요한 것
  1. KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 1 단계, 이미지 1/3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 1 단계, 이미지 2/3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 1 단계, 이미지 3/3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. KDDI Kyocera A5521K Front LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the screws using a Y0 screwdriver.
  3. KDDI Kyocera A5521K Front LCD Screen Replacement: 3 단계, 이미지 1/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 3 단계, 이미지 2/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 3 단계, 이미지 3/3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. KDDI Kyocera A5521K Front LCD Screen Replacement: 4 단계, 이미지 1/1
    • Use the Y0 screwdriver to remove the screws.
  5. KDDI Kyocera A5521K Front LCD Screen Replacement: 5 단계, 이미지 1/2 KDDI Kyocera A5521K Front LCD Screen Replacement: 5 단계, 이미지 2/2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. KDDI Kyocera A5521K Front LCD Screen Replacement: 6 단계, 이미지 1/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 6 단계, 이미지 2/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 6 단계, 이미지 3/3
    • Separate the faceplate from the phone.
  7. KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: 7 단계, 이미지 1/3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: 7 단계, 이미지 2/3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: 7 단계, 이미지 3/3
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  8. KDDI Kyocera A5521K Front LCD Screen Replacement: 8 단계, 이미지 1/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 8 단계, 이미지 2/3 KDDI Kyocera A5521K Front LCD Screen Replacement: 8 단계, 이미지 3/3
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
결론
Dominic Grisafe
회원 가입일: 04/15/10
157 평판
안내서 10개 작성하였습니다
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 회원
CPSU-REGAN-S10S28G25
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 19
전체 시간: 1,514
