주요 콘텐츠로 건너뛰기
KDDI Kyocera A5521K Speaker Replacement
필요한 것
  1. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: 1 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: 1 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: 1 단계, 이미지 3/3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. KDDI Kyocera A5521K Speaker Replacement: 2 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement: 2 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 3 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 3 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: 3 단계, 이미지 3/3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. KDDI Kyocera A5521K Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the screws using a Y0 screwdriver.
  5. KDDI Kyocera A5521K Speaker Replacement: 5 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement: 5 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement: 5 단계, 이미지 3/3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. KDDI Kyocera A5521K Speaker Replacement: 6 단계, 이미지 1/1
    • Use the Y0 screwdriver to remove the screws.
  7. KDDI Kyocera A5521K Speaker Replacement: 7 단계, 이미지 1/2 KDDI Kyocera A5521K Speaker Replacement: 7 단계, 이미지 2/2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. KDDI Kyocera A5521K Speaker Replacement: 8 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement: 8 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement: 8 단계, 이미지 3/3
    • Separate the faceplate from the phone.
  9. KDDI Kyocera A5521K Speaker Replacement, Speaker: 9 단계, 이미지 1/2 KDDI Kyocera A5521K Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Turn the phone over.
    • Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone so the exposed circuit board faces upward.
    • Keep the spudger in the speaker while turning the phone.
    • The speaker is indicated by the yellow rectangle.
  10. KDDI Kyocera A5521K Speaker Replacement: 10 단계, 이미지 1/2 KDDI Kyocera A5521K Speaker Replacement: 10 단계, 이미지 2/2
    • Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
  11. KDDI Kyocera A5521K Speaker Replacement: 11 단계, 이미지 1/3 KDDI Kyocera A5521K Speaker Replacement: 11 단계, 이미지 2/3 KDDI Kyocera A5521K Speaker Replacement: 11 단계, 이미지 3/3
    • Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
    • Firmly remove the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic Grisafe
회원 가입일: 04/15/10
157 평판
안내서 10개 작성하였습니다
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 회원
CPSU-REGAN-S10S28G25
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,831
