주요 콘텐츠로 건너뛰기
KLH Speaker Driver Replacement
필요한 것
  1. KLH Speaker Driver Replacement, Driver: 1 단계, 이미지 1/1
    • This is what the speaker will look like when you start.
    • Step 1: Remove the speaker cover.
  2. KLH Speaker Driver Replacement: 2 단계, 이미지 1/1
    • Step 2: Remove all 4 of the 2 cm screws.
  3. KLH Speaker Driver Replacement: 3 단계, 이미지 1/1
    • Step 3: Carefully remove the speaker from the speaker box. Be sure not to break the 2 wires connecting the speaker.
  4. KLH Speaker Driver Replacement: 4 단계, 이미지 1/1
    • Step 4: Carefully cut the 2 wires connecting the speaker. Make sure to cut the wires about half way from the speaker.
  5. KLH Speaker Driver Replacement: 5 단계, 이미지 1/1
    • Step 5: Make sure the the new speaker is the same size, and is ready to be placed inside the cabinet.
  6. KLH Speaker Driver Replacement: 6 단계, 이미지 1/1
    • Step 6: Strip both of the wires so they are ready to be soldered together.
  7. KLH Speaker Driver Replacement: 7 단계, 이미지 1/1
    • Step 7: Solder the wires together.
  8. KLH Speaker Driver Replacement: 8 단계, 이미지 1/1
    • Step 8: Screw the new speaker back into the box using all 4 of the 2 cm screws.
  9. KLH Speaker Driver Replacement: 9 단계, 이미지 1/1
    • Step 9: Place the cover back onto the speaker box.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gavin Giesmann
회원 가입일: 05/31/16
190 평판
안내서 1개 작성함
댓글 한 개
Be sure to note that the new speaker will have a burn in timed may not sound as good as the old till it gets played for awhile. It is important that the new speaker matches the old as the crossover may not work with a different speaker that does not match the original.
ronjon76 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 22
전체 시간: 1,603
