주요 콘텐츠로 건너뛰기
KLH Speaker Tweeter and Driver Replacement
필요한 것
  1. KLH Speaker Tweeter and Driver Replacement, Tweeter and Driver: 1 단계, 이미지 1/1
    • Remove the front speaker mesh to expose the speakers. The mesh will lift off without the use of tools.
  2. KLH Speaker Tweeter and Driver Replacement: 2 단계, 이미지 1/1
    • Once the mesh is removed, begin to remove the screws securing the small upper speaker/tweeter with a #1 Phillips head screwdriver.
  3. KLH Speaker Tweeter and Driver Replacement: 3 단계, 이미지 1/1
    • Once the screws have been removed, pry out the small upper speaker with an opening tool.
    • Take care not to damage the speaker’s wooden body while prying the speaker out.
  4. KLH Speaker Tweeter and Driver Replacement: 4 단계, 이미지 1/1
    • After you have removed the speaker, disconnect the red and brown wires from the speaker.
    • You might require needlenose pliers to do this.
  5. KLH Speaker Tweeter and Driver Replacement: 5 단계, 이미지 1/3 KLH Speaker Tweeter and Driver Replacement: 5 단계, 이미지 2/3 KLH Speaker Tweeter and Driver Replacement: 5 단계, 이미지 3/3
    • Remove the speaker from its plastic bezel using a #1 Phillips head screwdriver.
  6. KLH Speaker Tweeter and Driver Replacement: 6 단계, 이미지 1/1
    • For the larger bottom speaker, the same steps will be taken to remove the speaker.
    • Remove the four screws securing the speaker.
  7. KLH Speaker Tweeter and Driver Replacement: 7 단계, 이미지 1/1
    • Once the screws are removed, remove the speaker by either prying up from the top, or pushing the speaker through by pushing on the bottom of the speaker.
  8. KLH Speaker Tweeter and Driver Replacement: 8 단계, 이미지 1/2 KLH Speaker Tweeter and Driver Replacement: 8 단계, 이미지 2/2
    • Once the speaker is removed, remove the black and white wires.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mark Lee Hensley
회원 가입일: 06/01/16
126 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 2,528
