주요 콘텐츠로 건너뛰기
KPN Arizona Comfort Replacement
필요한 것
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: 1 단계, 이미지 1/3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: 1 단계, 이미지 2/3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: 1 단계, 이미지 3/3
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: 2 단계, 이미지 1/1
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: 3 단계, 이미지 1/3 KPN Arizona Comfort Replacement: 3 단계, 이미지 2/3 KPN Arizona Comfort Replacement: 3 단계, 이미지 3/3
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: 4 단계, 이미지 1/3 KPN Arizona Comfort Replacement: 4 단계, 이미지 2/3 KPN Arizona Comfort Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: 5 단계, 이미지 1/3 KPN Arizona Comfort Replacement: 5 단계, 이미지 2/3 KPN Arizona Comfort Replacement: 5 단계, 이미지 3/3
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: 6 단계, 이미지 1/3 KPN Arizona Comfort Replacement: 6 단계, 이미지 2/3 KPN Arizona Comfort Replacement: 6 단계, 이미지 3/3
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: 7 단계, 이미지 1/2 KPN Arizona Comfort Replacement: 7 단계, 이미지 2/2
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: 8 단계, 이미지 1/2 KPN Arizona Comfort Replacement: 8 단계, 이미지 2/2
    • Replace the broken speaker of the phone and solder it back in place.
결론
To reassemble your device, follow these instructions from step 6 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Maite
회원 가입일: 03/08/17
131 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 523
