주요 콘텐츠로 건너뛰기
Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement
필요한 것
  1. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
  2. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Lift the closure: 2 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the roaster steady while removing the plastic top/closure.
    • Panels may spring apart slightly once removed.
  3. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 3개
    • Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
  4. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull away the front panel carefully.
    • Take care not to damage the buttons while maneuvering the front panel.
  5. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove rear panel: 5 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove rear panel: 5 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove rear panel: 5 단계, 이미지 3개 중 3개
    • Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
    • The mains cable is routed through the panel and it will remain attached, place the panel in a soft bag if you wish to protect the paint throughout the rest of your repairs.
  6. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove element chamber screws: 6 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove element chamber screws: 6 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove element chamber screws: 6 단계, 이미지 3개 중 3개
    • Remove the 4x PH1 element chamber screws from the plastic bowl. (One screw not pictured)
    • When reassembling make sure there is no airgap indicated by the red and blue arrow
  7. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove roast chamber: 7 단계, 이미지 1개 중 1개
    • Set the roast chamber aside but do not disconnect any wires.
  8. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the element chamber: 8 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the element chamber: 8 단계, 이미지 2개 중 2개
    • Lift the element chamber up carefully to expose the element. Set this aside.
  9. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove support ring: 9 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove support ring: 9 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove support ring: 9 단계, 이미지 3개 중 3개
    • Lift up the element slightly and remove the support ring.
    • Do not touch the element coil directly. Skin oils can create hotspots on the wire.
  10. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Disconnect the element: 10 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Disconnect the element: 10 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Disconnect the element: 10 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver to remove the element leads from the terminal block.
  11. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the element: 11 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the element: 11 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Remove the element: 11 단계, 이미지 3개 중 3개
    • Pull the element leads through the fibreglass tubing to remove the element.
  12. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Checking the connections: 12 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Element Replacement, Checking the connections: 12 단계, 이미지 2개 중 2개
    • Double check the cable position, so that the screw is coming down on the wire and not the insulation of the element.
    • Head through to our wiki for instructions on recalibrating your fan speed and element resistance after replacing the element. Nucleus Link anemometer instructions can be found here.
결론
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
Kaffelogic Staff Kaffelogic Staff 회원
Community
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 55
전체 시간: 132
