주요 콘텐츠로 건너뛰기
Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement
필요한 것
  1. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
  2. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Lift the closure: 2 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the roaster steady while removing the plastic top/closure.
    • Panels may spring apart slightly once removed.
  3. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 3개
    • Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
  4. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull away the front panel carefully.
    • Take care not to damage the buttons while maneuvering the front panel.
  5. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 3개
    • Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
    • The mains cable is routed through the panel and it will remain attached, place the panel in a soft bag if you wish to protect the paint throughout the rest of your repairs.
  6. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Boards may vary: 6 단계, 이미지 1개 중 1개
    • Boards may vary, the PCB in your roaster may not look like the one in this guide, but the steps should still match the general replacement process.
    • All replacement boards will have a USB-C connection. You will have to migrate any custom profiles on your USB stick to the onboard storage with Kaffelogic Studio.
  7. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect the SSR signal: 7 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect the SSR signal: 7 단계, 이미지 2개 중 2개
    • Pull upwards on the SSR signal connector to remove it.
  8. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect the thermocouple: 8 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect the thermocouple: 8 단계, 이미지 2개 중 2개
    • Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
  9. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, White thermocouple connector: 9 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, White thermocouple connector: 9 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, White thermocouple connector: 9 단계, 이미지 3개 중 3개
    • If your thermocouple connector looks like this, you will need to follow this step.
    • Use the end of a cable tie or very small plastic spudger to open the contact and remove your thermocouple wires. You may need to trim the cable tie end to fit into the slot.
  10. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove motor controller signal: 10 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove motor controller signal: 10 단계, 이미지 2개 중 2개
    • (Applicable to early models) Pull upwards on the motor controller signal connector to remove it.
    • Black wire to the left when replacing.
  11. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect/desolder the motor: 11 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect/desolder the motor: 11 단계, 이미지 2개 중 2개
    • Unplug your motor if your roaster is fitted with a connector, otherwise de-solder the motor controller power.
  12. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Disconnect the ribbon cable: 12 단계, 이미지 1개 중 1개
    • Carefully pull on the ribbon cable to remove it.
    • Some boards have a larger cable on the other side of the PCB.
  13. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove PCB screws: 13 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove PCB screws: 13 단계, 이미지 2개 중 2개
    • Remove the 4x PH2 PCB screws.
  14. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, De-solder the power wires: 14 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, De-solder the power wires: 14 단계, 이미지 2개 중 2개
    • Prepare your soldering iron and de-solder/reflow the two transformer wires to remove them.
  15. Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the board: 15 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the board: 15 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) Mainboard Replacement, Remove the board: 15 단계, 이미지 3개 중 3개
    • Your mainboard is now removed and ready for rework or replacement. Replace the serial code on the bottom of your roaster with the included QR label.
    • Head through to our wiki for instructions on recalibrating your fan speed and setting the voltage and element resistance after replacing the mainboard.
    • Nucleus Link anemometer calibration instructions can be found here.
결론
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
Kaffelogic Staff Kaffelogic Staff 회원
Community
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 64
