주요 콘텐츠로 건너뛰기
Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement
필요한 것
  1. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
  2. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Lift the closure: 2 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the roaster steady while removing the plastic top/closure.
    • Panels may spring apart slightly once removed.
  3. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 3개
    • Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
  4. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull away the front panel carefully.
    • Take care not to damage the buttons while maneuvering the front panel.
  5. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove rear panel: 5 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove rear panel: 5 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove rear panel: 5 단계, 이미지 3개 중 3개
    • Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
    • The mains cable is routed through the panel and it will remain attached, place the panel in a soft bag if you wish to protect the paint throughout the rest of your repairs.
  6. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Disconnect gantry cables: 6 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Disconnect gantry cables: 6 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Disconnect gantry cables: 6 단계, 이미지 3개 중 3개
    • Disconnect the SSR signal lead and motor from the PCB-A
  7. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove gantry screws: 7 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove gantry screws: 7 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove gantry screws: 7 단계, 이미지 3개 중 3개
    • Remove the 4x PH2 screws securing the gantry plate to the base.
    • Be sure to place the earth spade under the screw head when reassembling.
  8. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Lift the stack: 8 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Lift the stack: 8 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Lift the stack: 8 단계, 이미지 3개 중 3개
    • Tip the stack forward to gain access to the SSR.
  9. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove trigger lead: 9 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove trigger lead: 9 단계, 이미지 2개 중 2개
    • Use a PH2 screwdriver to remove the trigger lead.
    • Note that this connection is polarized. Connect red/orange to (+) and black/brown to (-) markers on the SSR.
  10. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the mains wiring: 10 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the mains wiring: 10 단계, 이미지 2개 중 2개
    • Use a PH2 screwdriver to remove the two mains spade terminals.
  11. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the SSR screws: 11 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, Remove the SSR screws: 11 단계, 이미지 2개 중 2개
    • Remove the 2x PH2 screws securing the SSR to the bottom of the gantry plate.
  12. Kaffelogic Nano 7/LINK (A/B/C-N Serial) SSR Replacement, SSR removed: 12 단계, 이미지 1개 중 1개
    • SSR can now be pulled out of the roaster and replaced.
결론
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
Kaffelogic Staff Kaffelogic Staff 회원
Community
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 48
