주요 콘텐츠로 건너뛰기
Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement
필요한 것
  1. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Removing Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
  2. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Lift the closure: 2 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the roaster steady while removing the plastic top/closure.
    • Panels may spring apart slightly once removed.
  3. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove bottom panel screws: 3 단계, 이미지 3개 중 3개
    • Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
  4. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull away the front panel carefully.
    • Take care not to damage the buttons while maneuvering the front panel.
  5. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove rear panel: 5 단계, 이미지 3개 중 3개
    • Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
    • The mains cable is routed through the panel and it will remain attached, place the panel in a soft bag if you wish to protect the paint throughout the rest of your repairs.
  6. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Disconnect the SSR signal: 6 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Disconnect the SSR signal: 6 단계, 이미지 2개 중 2개
    • Pull upwards on the SSR signal connector to remove it.
  7. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Disconnect the motor: 7 단계, 이미지 1개 중 1개
    • Unplug your motor if your roaster is fitted with a connector, otherwise leave the connections in place.
  8. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Disconnect the ribbon cable: 8 단계, 이미지 1개 중 1개
    • Carefully pull on the ribbon cable to remove it.
  9. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove PCB screws: 9 단계, 이미지 1개 중 1개
    • Remove the 4x PH2 PCB screws.
  10. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Pull the board: 10 단계, 이미지 1개 중 1개
    • Pull the board away from the chassis carefully, taking care with any wires still attached. We need to get to the back of the board.
  11. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove shroud screws: 11 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove shroud screws: 11 단계, 이미지 2개 중 2개
    • Remove the 2x 1.5mm hex screws securing the plastic USB shroud.
  12. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove shroud: 12 단계, 이미지 1개 중 1개
    • Slide the plastic shroud away from the PCB
  13. Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove the daughterboard: 13 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (C-N Serial) USB Daughterboard Replacement, Remove the daughterboard: 13 단계, 이미지 2개 중 2개
    • Pull away on the daughterboard to remove it from the main PCB.
결론
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
Kaffelogic Staff Kaffelogic Staff 회원
Community
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 86
전체 시간: 127
