주요 콘텐츠로 건너뛰기
Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement
필요한 것
  1. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing Front Panel Screws: 1 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing Front Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
    • Take care not to damage the buttons while maneuvering the front panel, with all six screws removed it may fall away.
  2. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Lift the closure: 2 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the front panel steady while removing the plastic top/closure.
  3. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the front panel: 3 단계, 이미지 1개 중 1개
    • Pull away the front panel carefully.
  4. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: 4 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: 4 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: 4 단계, 이미지 3개 중 3개
    • Remove the last 2.5mm Hex screw securing the rear panel.
    • Pull up on the rear panel to remove it from the roaster.
  5. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Access granted: 5 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Access granted: 5 단계, 이미지 2개 중 2개
    • Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
  6. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: 6 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: 6 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: 6 단계, 이미지 3개 중 3개
    • Remove the 2x 2.5mm Hex screws securing the cable carrier to the base.
    • Be careful not to lay the roaster on its front as the buttons can be damaged or broken off.
  7. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: 7 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: 7 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: 7 단계, 이미지 3개 중 3개
    • Remove the terminal PCB cover and set it aside. This is held in with four small plastic clips at each corner.
  8. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: 8 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: 8 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: 8 단계, 이미지 3개 중 3개
    • Disconnect the mains cables. Marked an N (Neutral) and L (Live)
  9. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: 9 단계, 이미지 3개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: 9 단계, 이미지 3개 중 2개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: 9 단계, 이미지 3개 중 3개
    • Remove the mains earthing connector from the tab. Pliers can be used for this as it can be tight.
  10. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Cable removed: 10 단계, 이미지 2개 중 1개 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Cable removed: 10 단계, 이미지 2개 중 2개
    • Your mains cable is now free, and ready for repair or replacement.
결론
첨부 문서
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
Kaffelogic Staff Kaffelogic Staff 회원
Community
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 65
