소개
Use this guide to remove and replace the check valve on the underside of a Karcher Carpet Cleaner BRC3015C 2018.
필요한 것
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a flathead screwdriver to loosen the hose clamps at each end of the check valve hose.
다른 2명이 해당 안내서를 완성하였습니다.
