소개
Use this guide to remove the pump cover in a Karcher Carpet Cleaner BRC3015C 2018.
필요한 것
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
