소개
Use this guide to remove and replace a pump in a Karcher Carpet Cleaner BRC3015C 2018.
This guide shows the removal process for just one pump. If you wish to remove the other pump, you may apply these same steps to remove it.
필요한 것
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a flathead screwdriver to loosen the hose clamps at both ends of the pump.
Use your fingers to unscrew the hose barb from the outward-facing end of the pump.
다른 4명이 해당 안내서를 완성하였습니다.
