소개
Use this guide to remove and replace the pump assembly on a Karcher Pressure Washers 11073080 2017.
필요한 것
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 14 mm socket to remove the four bolts securing the pump assembly to the pressure washer.
The new pump assembly will come with a plug in the oil port. After installing the new pump assembly, remove this plug.
Replace the plug with the dipstick from the old pump assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Estamos interesados en un kit de reconstruccion de una bomba Karcher HD 9/23 DE
Atentamente,
Vicente
