소개
Use this guide to remove and replace the unloader on a Karcher Pressure Washers 11073080 2017.
필요한 것
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips #2 screwdriver to loosen the hose clamp securing the hose to the unloader.
Pull the end of the hose that's attached to the unloader straight off of the unloader.
Use an 11/16" wrench to remove the straight nozzle from the unloader.
Remove any thread seal tape, and clean any thread locker off of all the fittings, nozzles, and plugs that will be transferred to the new unloader.
다른 2명이 해당 안내서를 완성하였습니다.
