주요 콘텐츠로 건너뛰기
Katadyne Hiker Water Filter Cleaning
필요한 것
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: 1 단계, 이미지 1/1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: 2 단계, 이미지 1/1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: 3 단계, 이미지 1/3 Katadyne Hiker Water Filter Cleaning: 3 단계, 이미지 2/3 Katadyne Hiker Water Filter Cleaning: 3 단계, 이미지 3/3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: 4 단계, 이미지 1/3 Katadyne Hiker Water Filter Cleaning: 4 단계, 이미지 2/3 Katadyne Hiker Water Filter Cleaning: 4 단계, 이미지 3/3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: 5 단계, 이미지 1/1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: 6 단계, 이미지 1/1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: 7 단계, 이미지 1/1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: 8 단계, 이미지 1/2 Katadyne Hiker Water Filter Cleaning: 8 단계, 이미지 2/2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
결론
If difficulty pumping persists, a new filter is required.
다른 한 분이 해당 안내서를 완성하였습니다.
Dylan Carey
회원 가입일: 02/24/15
130 평판
안내서 1개 작성함
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 회원
CPSU-GREEN-W15S24G6
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 28
전체 시간: 770
