주요 콘텐츠로 건너뛰기
Kenmore 110 Series Washing Machine Drive Belt Replacement
필요한 것
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: 1 단계, 이미지 1/1
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 3/3
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 3/3
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Robert Trout
회원 가입일: 09/26/12
1,234 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 11개 작성하였습니다
댓글 9개
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - 답글
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - 답글
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - 답글
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 131
30일 전: 623
전체 시간: 122,943
