주요 콘텐츠로 건너뛰기
Kenmore 110 Series Washing Machine Drive Belt Replacement
필요한 것
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: 1 단계, 이미지 1/1
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 2 단계, 이미지 3/3
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 3 단계, 이미지 3/3
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
    I have difficulty to remove the bolt suring the pulley. Is there any tricky to move the bolt?
    John Wang - 답글
    need to remove shaft off pulley
    Valery Ryz -
    I have a very old Kenmore Washer. The belt is loose but not broken. How do I tighten?
    teedle54 - 답글
    Thank you for the help .
    Tesa Martin - 답글
    what is the shaft? we can't get our on either
    Jeff Maddox - 답글
    How can I Kno if it's the motor coupler or belt? Around the coupler is white plastic shavings.
    Shelley's 3 - 답글
    The new belt is rigid and we're unable to stretch around the larger wheel. Any tricks?
    Bill Lescarbeau - 답글
결론
다른 18명이 해당 안내서를 완성하였습니다.
Robert Trout
회원 가입일: 09/26/12
1,234 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 11개 작성하였습니다
댓글 8개
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - 답글
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - 답글
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - 답글
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - 답글
I have a Kenmore washer model # 110.16852500 I need the belt for this washer please it gives me everything but the belt
Darryl Goodwin - 답글
یک وبسایت تخصصی توی بحث تعمیرات ماشین لباسشویی در مشهد سایت مشهد تعمیر هستش که نمایندگی رسمی بیشتر از ۳۰ برند مانند سامسونگ الجی دوو بوش اسنوا ایندزیت و... هستش
Saeed Dopamine - 답글
How to tell if it's belt or coupler? I have white plastic shavings around it.
Shelley's 3 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 151
30일 전: 737
전체 시간: 121,401
