소개
Use this guide to replace a faulty electronic control on your Kenmore 110 Washing Machine.
부품
지정된 부품이 없습니다.
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
I am having the same problem. Did you ever find a fix?
