주요 콘텐츠로 건너뛰기
Kenmore 110 Series Washing Machine Electronic Control Replacement
필요한 것
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: 1 단계, 이미지 1개 중 1개
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 3개 중 1개 Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 3개 중 2개 Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 3개 중 3개
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: 3 단계, 이미지 2개 중 1개 Kenmore 110 Series Washing Machine Electronic Control Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Robert Trout
회원 가입일: 09/26/12
1,234 평판
안내서 5개를 작성함
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 12개를 작성함
3가이드 댓글
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - 답글
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 123
전체 시간: 30,612
