주요 콘텐츠로 건너뛰기
Kenmore 110 Series Washing Machine Electronic Control Replacement
필요한 것
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: 1 단계, 이미지 1/1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Electronic Control Replacement: 2 단계, 이미지 3/3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: 3 단계, 이미지 1/2 Kenmore 110 Series Washing Machine Electronic Control Replacement: 3 단계, 이미지 2/2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Robert Trout
회원 가입일: 09/26/12
1,234 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 11개 작성하였습니다
댓글 3개
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - 답글
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 44
30일 전: 150
전체 시간: 27,607
