이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
From the bottom, pull out and remove the component cover.
Carefully remove the three wire harnesses.
With a phillips head screwdriver, remove the three mounting screws.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 3개
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
I am having the same problem. Did you ever find a fix?
