주요 콘텐츠로 건너뛰기
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
필요한 것
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: 1 단계, 이미지 1/1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 2 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 2 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 2 단계, 이미지 3/3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 3 단계, 이미지 1/3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 3 단계, 이미지 2/3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 3 단계, 이미지 3/3
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Robert Trout
회원 가입일: 09/26/12
1,234 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 11개 작성하였습니다
댓글 4개
how to test water level switch??
countryrhoads4x4 - 답글
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - 답글
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 45
30일 전: 144
전체 시간: 39,800
