주요 콘텐츠로 건너뛰기
소개
Use this guide to replace a faulty water level sensor.
  1. Unplug the washing machine!
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover. From the bottom, pull out and remove the component cover. From the bottom, pull out and remove the component cover.
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Remove wires from water level sensor. With a Phillips screwdriver remove the mounting screw. Cut the zip tie and remove water level hose.
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Robert Trout
회원 가입일: 2012년 09월 26일
1,009 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 회원
CPSU-FORTE-F12S15G43
5 회원들
안내서 10개 작성하였습니다
how to test water level switch??
countryrhoads4x4 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 26
30일 전: 135
전체 시간: 33,047
